Z axis not responding
Discussion in 'CNC Mills/Routers' started by Slandis, May 31, 2020.
  1. Slandis
    Slandis New
    Hello all, just finished building my Lead 1010 machine. I am going through trying to test everything and the Z axis is not responding. The motor appears to have no power going to it. The other axis jog just fine. On the black box the LED for the Z is lit up. Any help would be appreciated.
    Indicates
    - overcurrent (adjust current down)
    - overtemp (adjust current down, check fan, check heatsinks are installed)
    - short circuit (check wiring)
    - low input voltage (check PSU is delivering 24v)
  3. Slandis
    Slandis New
    I have checked all of those except the voltage from the power supply. I will check that and report back. Thank you.
    Swop in X motor onto Z too just as a check of the wiring etc
    And remember to power cycle the board to clear the error
  5. Slandis
    Slandis New
    I
    I checked the power supply and its showing 24.13. I tried to swap the wires and it did not change. I even unhooked everything and turned it on and the Z light still comes on.
    Alright, thanks for the tests :)
    please email http://support.openbuilds.com/support/home to request an RMA for a replacement Muscle board, please include a link to this thread to help expedite the request (Testing already done above)
  7. Slandis
    Slandis New
    Thank you for the help.
  8. Slandis
    Slandis New
    Just want to let everyone know I got a new box and everything is working great, great customer support. Thanks for the help everyone.
