Mach3 to more modern setup
Discussion in 'Controller Boards' started by Darriel Fisher, Jun 10, 2020.
  1. Darriel Fisher
    I may need help to change from Mach3 to your stuff ,Do i still use the TB6000's ????
  2. Giarc
    You can use an Arduino board with those drivers and use Openbuilds software. They are connected in a similar fashion as the DQ542MA drivers. There is a resource for connecting those in the resources section above. It is definitely not an easy plug and play like the Black box though.
    1) order a BlackBox 4X
    2) read through OpenBuilds BlackBox 4X Documentation
    3) Easy, have fun
