4Axis Controller Bundle wiring
Discussion in 'CNC Mills/Routers' started by rooter, Jun 26, 2020.
  1. rooter
    rooter New
    SPAM 3D calls it a "4Axis Controller Bundle", but it's really a three axis router with two motors on the Y-axis.
    When I wire the Y-axes, do I wire the second Y-axis to the A-axis inputs and have the software duplicate the Y-axis on the A-axis somehow or do I just double up the wires on the Y-axis inputs? Maybe I need to do a combination of the two and have the voltage separate and the signal shared?
  2. Giarc
    Have you reached out to SPAM customer support? Or Googled "Novusun CNC controller manual?"
    Replace is with a BlackBox (and shou genuine machine hehe) . Not only easier, but also comes with awesome documentation at start [OpenBuilds Documentation] all our support and after sales service
  4. rooter
    rooter New
    Update: I found a video that explains everything. Wire the A axis normally. Don't double anything up. You then set the A axis as a slave to the Y axis in the software. See video for details:
