surfacing tool on my workbee 1510
Discussion in 'Control Software' started by Gfrog, Jul 7, 2020.
  1. Gfrog
    Gfrog New
    You deleted the value (it was prepopulated as 3mm) from Skim Depth, you cannot use an empty value for Skim Depth: Try again, but enter a number
    #2 Peter Van Der Walt, Jul 7, 2020
  3. Gfrog
    Gfrog New
    Peter, thanks for your help, I`M very new at this but I love the work bee 1510!!!!
  4. Gfrog
    Gfrog New
    Hello Peter,
    So I tried what you advised but I can`t get to that gcode, so I went into surfacing wizard and I left all the set parameter as shown above. the work bee 1510 starts to move and then makes a z move to the limit switch and faults out. my bigger concern is if I change ANY parameters in surfacing wizard, (tool size , width, ect.) and select the proceed button my open build control screen goes white and locks, the only way to get it back is to restart my PC. Help please.
    1) Try a different computer
    2) Make sure your values are sane (not using like 1% stepover or something crazy like that)
    If it moved up to the switch you probably forgot to SETZERO (where the job must run from: for surfacing wizard the origin is bottom, left, right on top of the spoilboard. Jog there, setzero)
    To understand setting zero: watch
    It's as simple as:
    (substitute your own actual working area dimensions, bit sizes, feed, speeds and depths of course)
    Note before clicking run, I jog my bit over to where the job must start from and zero out
    #6 Peter Van Der Walt, Jul 8, 2020
