Port closed issue “blackbox”
Discussion in 'General Talk' started by alikw, Jul 11, 2020.
  1. alikw
    alikw New
    Hi
    Everything was fine in the past weeks. Today I got this problem that port closed. Same to this thread
    Blackbox issue Please help *port closed*
    I got this problem about a week ago. I just did a restart for the laptop and then it worked fine but today it doesn't work.
  2. Nitehawkhp
    I've had that same problem and it is been very frustrating for me. I have tried many things to resolve this issue, and to date, the only thing that works for me is the following:
    1. Turn off the power supply feeding the black box
    2. Turn off the power on the black box
    3. Disconnect the USB cable on the black box
    4. Turn on the power supply feeding the black box
    5. Turn on the power on the black box
    6. Plug in the USB cable to the black box
    When I have performed those steps, the black box is recognized by the computer and the OpenBuilds software can then connect to it. I don't know if you'll have the same luck, but that is what has worked for me.
    Rod
  3. alikw
    alikw New
    Thank you, still doesn’t work
  4. alikw
    alikw New
    And when I try a flashing tool, it’s failed
  5. Nitehawkhp
    Have you tried clicking on the blue install drivers box to see if that will help?
  6. alikw
    alikw New
    When I connect the USB to laptop this happen.
    nothing show to install
  7. alikw
    alikw New
    When I connect the USB to laptop this happen. Previously, I think the green signal is continuous
  8. Nitehawkhp
    One last thing. Have you tried to reinstall the Openbuilds Software?
  9. alikw
    alikw New
    Yes in mac and window
  10. alikw
    alikw New
    I noticed that when I shout down my laptop this shaw off but when i switch on it disappears
    Usb led colors has no deeper meaning. They just indicate rx/tx read the FT232RL datasheet if you want to know more
    More likely miswiring somewhere. Disconnect everything but the USB cable.
    A wrongly wired limit switch can short out the 5v rail and even damage the board. Refer to docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation]
  12. alikw
    alikw New
    Still doesn’t work, I tried all the solutions in this page. T
  13. alikw
    alikw New
    I take off all wires. Flash is failed in windows
    #13 alikw, Jul 11, 2020
  14. alikw
    alikw New
    This is on mac. Flash is compete
  15. Nitehawkhp
    I don't know enough to help you further. Sorry.
    alikw likes this.
  16. alikw
    alikw New
    thank you brother. i appreciate that
    As if flashed successfully on the Mac it shows the controller is still alive.
    Did you test with only USB connected (no other wiring) on the mac yet?
    Any known events from when it worked till it didn't? Known shorts, accidentally disconnected a stepper motor while power was on, power surge, metal chips fell into case, yanked out USB cable damaging connector?
  18. alikw
    alikw New
    yes, I tested with only usb without any wires but nothing change
    Nothing happened recently. I ran as a normal. All wires are connected properly. No shorts or accidentally disconnected
  19. Peter Van Der Walt
    Which version do you have? Its printed on the Brains board. V2.4 - 2.7?
  20. alikw
    alikw New
    V2.7
  21. Peter Van Der Walt
    Move the Autoreset jumper to USB Mode. Ie open Autoreset on the left, close USB mode on the right
    alikw likes this.
  22. alikw
    alikw New
    Still doesn’t work
  23. alikw
    alikw New
    Any further solutions please
  24. Peter Van Der Walt
    None at this time, seems something damaged it, from here its hard to tell you what happened to it
    Just adding to the above: Normally IT troubleshooting steps:
    tried different USB cable?
    tried different pc?
  25. alikw
    alikw New
    So what I do? I have not made any extensions or changes after assembly the lead cnc before 2 weeks. Do I need to contact the store?
  26. alikw
    alikw New
    I tried another 1 usb cables and 3 pc
    1 windows that I was working with it and now says “flash failed” port closed.
    The other 2 are mac pro and iMac both of them “flash complete” but also port closed
  27. Peter Van Der Walt
    Correct yes, next step is to contact the store, including a link to this thread
  28. alikw
    alikw New
    I apologize for the many questions. I am zero in these electrical and technical things, so I ask a lot. Thanks for your quick response and for providing all the solutions.
  29. alikw
    alikw New
    I install the UNO Arduino with friend help. It is connect perfectly, but still I want to install the limit switch and the probe.
  30. Rob Taylor
