Error Code
Discussion in 'Control Software' started by KEITHABEAR, Jul 12, 2020.
  1. KEITHABEAR
    KEITHABEAR Well-Known
    Similar to error:22 - Gcode from Vectric? Which post processor are you using?
    Post the vectric project, post you used and resultant gcode.
  3. Alex Chambers
    Suspect recent major Vectric upgrade - did you migrate everything (especially post processors) from your previous version if this might apply to you?
  4. KEITHABEAR
    Try Openbuilds-mm or Grbl-mm as a quick test.
  6. KEITHABEAR
    I am using the same post processor I've always used
    Yes but vectric updates may have overwritten your old one. Try the mm one, lets see if that helps, then we ask Vectric to look at the Inch one if that is the case... you can only help troubleshooting by following the suggestions please
  8. KEITHABEAR
    That is it works in mm
    Ok use mm for now, we’ll log an issue with Vectric to check their Grbl-inch posts
  10. KEITHABEAR
    Thanks for the help much appreciated
  11. Alex Chambers
    This is the "old" inch post processor from Vectric - I haven't had a chance to test it.
    PS Vectric claim the latest release (today) fixes the problems with the grbl post processors. It doesn't mention Openbuilds or Duet versions.
    #11 Alex Chambers, Jul 14, 2020
