New kid in the block need some advice......
Discussion in 'General Electronics' started by zz0122, Jul 13, 2020.
  1. zz0122
    zz0122 New
    great forum, I've been following for a while..
    Im planning to upgrade my workbee 1510 with VFD. and I have a few question I try to figure it out.
    I have general question regarding VFD earth ground and NVUM ground.
    My concern is the VFD used earth ground and its connected to the body all the way to the tip of the bit, NVUM used the negative of the power supply to do z-probing (Mach3 active low). since those 2 unit used different kind of grounding, how can I do z-probing?
    sorry with my bad English...
    Yan
  2. David the swarfer
  3. zz0122
    zz0122 New
    Thanks, I definitely gonna try that....
