Mophorn A2-8040 VFD Setup with Blackbox
Discussion in 'CNC Mills/Routers' started by ward0n, Jul 26, 2020.
  1. ward0n
    ward0n New
    I am setting up a Mophorn 220v 4KW air cooled spindle with an A2-8040 VFD
    Have read through the Openbuilds documentation for setting up the 0-10v analog signal to the Toolhead
    and have watched and read the manuals for the Huanyang & YL620-A VFD setups I found on the forum.
    I have identified 3 out of the 4 same terminals on my VFD compared to the others and I'm not seeing the additional GND connection, or don't know which terminal to pair with the GND I do have. I have included photos of the documentation and schematic. Would anyone have any insight or recommendations on how this would be setup? IMG_20200726_084457209.jpg IMG_20200726_084433305_HDR.jpg IMG_20200726_084621209.jpg IMG_20200726_084631233.jpg
    Might be best to confirm with the VFD supplier. But in the absense of other GND pins, i suspect you can just gang up all the GNDs as a common GND. They may just have been displayed seperately in the schematic to avoid clutter
  3. ward0n
    ward0n New
    Thank you for the reply! I was considering the same thing with the common GND. I will give it a shot next weekend.
  4. Scot Paxton2
    How did you make out? I would be interested in seeing some pictures if you are willing to share your outcome as I am trying to do the same. Thanks in advance.
