STEP Parts Library 1.5
Complete set of OpenBuilds parts in a generic 3D format.
  1. Rob Stehlik
    OpenBuilds Parts for your projects!
    STEP OpenBuilds Parts Library
    Official OpenBuilds Part Models commissioned by OpenBuilds,LLC
    This is a copy of the Solidworks 2014 part library. Drawings are included for reference.
    Disclaimer
    By downloading any information or materials from this website you agree and acknowledge that all information or materials are provided as is without any guarantees or warranty of any kind. In association with any downloads or any other information or materials contained on this website, OpenBuilds, LLC makes no warranties of any kind, either express or implied, including but not limited to warranties of merchantability, fitness for a particular purpose, of title, or of noninfringement of third party rights. Use of the download by a user is at the user's risk. OpenBuilds, LLC is not responsible for accuracy or reliability of any content or safety recommendations or lack thereof. Use of any information from this website is at the user's own risk. This website is community driven and by joining you are agreeing to all terms and conditions set forth, therefore you agree that as a user of this site you are solely responsible of all of your own actions.
    Ownership
    The 3D models and/or materials made available by OpenBuilds,LLC are protected by copyright and other intellectual property rights which includes all images and digital 3D model information. OpenBuilds,LLC owns all rights, titles and interest and reserves all rights in and to these materials not expressly granted to you in these Terms.
    NO REPRESENTATIONS OR WARRANTIES, EITHER EXPRESS OR IMPLIED, OF MERCHANTABILITY, FITNESS FOR A SPECIFIC PURPOSE, THE DOWNLOAD MAY BE USED WITHOUT INFRINGING THE INTELLECTUAL PROPERTY RIGHTS OF OTHERS, OR OF ANY OTHER NATURE ARE MADE WITH RESPECT TO INFORMATION OR THE DOWNLOAD TO WHICH INFORMATION MENTIONS. IN NO CASE SHALL THE INFORMATION BE CONSIDERED A PART OF OUR TERMS AND CONDITIONS OF SALE.
Recent Reviews
  1. Captain Waclaw
    Captain Waclaw
    Version: 1.5
    Przydatne informacje.
  2. Gabriel Faber
    Gabriel Faber
    4/5,
    Version: 1.5
    Nice set of parts. One question: Description says "Drawings are included for reference", but I don't see them in the (1.5) .zip file
  3. scopemannn
    scopemannn
    2/5,
    Version: 1.5
    There are no teeth on any of the timing belt pulley models despite being labelled as having specific teeth counts.
    Is this intentional, if so what's the point? Otherwise, glaring mistake that needs fixing
  4. Maybegus
    Maybegus
    3/5,
    Version: 1.5
    Could you add the C Beam motor mount plate? Thanks.
  5. antek
    antek
    Version: 1.5
    THX :)
  6. Kabir
  7. John Harshman
    John Harshman
    Version: 1.5
    This is very useful - Could you do me a favor - I need the 250mm version of the Nema 23 V slot Lead Screw Driven actuator. The 500mm version is in the assemblies and I was hoping not to re-draw it. It is in the OpenBuild documents so I am hoping you have the translator for Sketch Pro to Solidworks which I do not have. Great Work - thanks!
  8. Daniel Martinez
    Daniel Martinez
    4/5,
    Version: 1.5
    It is a great resource and I appreciate.
    One thing that would be useful is if the measurements were a little more precise because the wheels don't seem to be fitting the v slots when mounted to the plate(in Fusion), even if you rotate the eccentric spacer to the farthest position the distance between the wheels is a little bit too short for the extrusion to fit.
    I don't know if the dimensions of the wheels are too big, or the extrusion is too big, or maybe the wholes in the plate are a little bit too close(I suspect this last one is the problem)
  9. Andre Els
    Andre Els
    Version: 1.5
    Very good, thanks for doing this, very helpful. Once thing I did notice though, the mini bearing 5x10x4.2 in the STEP file, but website says it is 5x10x4. So two of those and the 3.9mm depth of the mini v-wheel and it's about 0.6mm difference ? is the bearing 4mm or 4.2mm ... thanks !
    1. Rob Stehlik
      Author's Response
      Good question! I don't have one of the bearings here otherwise I would measure it. I can't remember why I made the CAD model 4.2mm. I'll find out and let you know.
  10. StevenR01
    StevenR01
    Version: 1.4
    Just what I was looking for. Am using FreeCAD and the STEP file format works great there. This entire site/community is just what I was looking for. May be attempting to build a large 3d printer using linear actuator assemblies or may just use them to expand/improve a Creality CR-10, if it ever ships. Prices are great here and the support will be most helpful too.
