Jokers & Pegs
Rating:
Tags:
  • Machine Type:
    Other Machine
    Software:
    Openbuilds
    Electronics:
    OpenBuilds BlackBox
    Machine Time:
    About 25 minutes for each one. Another 7 minutes for laser engraving
    Bit or Laser Size:
    1/8” drill bit, 60 degree v bit, 1/4” up cut end, 1” surfacing bit, mill, 2w Opt laser
    Feeds & Speeds:
    Drill: 10000 rpm (lowest I can go)
    Other bits: 15000 rpm. Feed rates default from VCarve Pro.
    Materials:
    Hardwood flooring
    8 species of wood. Plan was purchased on Etsy, saving me a lot of design time. I tweaked it a little. Pegs purchased at a local supplier. The wood is about 14mm thick as I had to plane it down to remove the grooves from the bottom of the flooring. I used a three flute surfacing bit for that.
David of Finella and Mark Carew like this.
  1. Mark Carew
    1. Dale Stewart
      You’re welcome. I have a friend who wholesales flooring. He has moved his office twice and gave me all the samples each time.
      Dale Stewart, Aug 5, 2024
    2. Mark Carew
      Sweet! can't beat that deal. Thats what I call a good friend :)
      Mark Carew, Aug 5, 2024
