- Machine Type:
- Laser / Plasma
- LaserWeb4
- Machine Time:
- About 1 min
- 0.1 laser diameter
- Feeds & Speeds:
- 50 mm/s and 20 mm/s
- Dry moly lube https://amzn.to/2K5s5CG
This is not much o a project but a useful process for other projects. Marking metals with CO2 laser its not possible unless you use those expensive Cermark or similar solutions.
A log time ago i played with the alternative which is Dry Moly Lube and got very good results but never documented the process so i decided to pass this along for others.
The moly used is the CRC brand.
Laser is a K40 CO2 modified to a bigger work area, project can be found here UK40OB
Hope someone finds its useful, thanks
