Small picture holder themed for valentines day. Great gift or home decoration.
- Fusion 360
- Machine Time:
- 4:30
- 1/8
- Feeds & Speeds:
- 1150 mm/min 2mm doc
- white hdpe .25"
-I made this on a Mini Mill with 1/8 kyrocera end mills. I ran it at 1150mm/min with 2mm doc and had my colt router on setting 3. I had 5 tabs around the perimeter and cut those off with clippers when it was done, then I sanded and deburred the shape. I use a small drill bit to make a hole on top of the L and then bent a paper clip so it could hold pictures. I used a little ca glue to hold it in the hole and it was done.![]()
