Trial run for a memorial plaque for my wife's grave.
- Machine Type:
- OpenBuilds WorkBee
- Vectric V-carve
- Electronics:
- Other Controller
- Machine Time:
- 3 & 1/2 hours
- 0.5 mm tapered ballnose, 45 degree V bit
- Feeds & Speeds:
- 14K rpm, 600 - 2400 min/min
- Slate
JPG converted to low relief (STL) using blender.
Slate machined on my Workbee (upgraded with linear rails)
0.5 mm tapered ballnose for the low relief, 45 degree V bit for the lettering.
Started at 14 K rpm, 600 mm/min. Increased to 1200 mm/min during the job.
Lettering added at 2400 mm/min, 0.25 mm doc, 1 mm flat depth.
Waterbath used for cooling and to control dust.
			Alain JBT, mike norton, Ariel Yahni and 2 others like this.
