Another fast project using the LEAD 1010 CNC milling machine.
- Machine Type:
- OpenBuilds LEAD Machine
- Inkscape, Fusion 360, Openbuilds Control
- Electronics:
- xPRO Board
- Machine Time:
- ca. 20 min
- 3.175mm
- Feeds & Speeds:
- 1800 mm/min
- MDF
This time in a few minutes we created a LED wall lamp. - this is a prototype version.
We used MDF, strip LED and power supply for this purpose.
To make a design, just a piece of MDF (~ 700mm x 290 mm x 10 mm) or 3 smaller pieces, e.g. 3 x 300x300 mm
Work in MDF is fast and with a low-class cutter you can work at speeds over 1800mm / min.
As it is a prototype, we have opened additional holes, e.g. for the power supply. In our first model, we used a simple cheap plug-in power supply.
The amount of LED strip with a power of 9.6W / m is about 2m (exactly not measured).
LED strip for 12V security.
Power supply power approx. 2.5A (30W).
MDF black paint / spray.
MDF elements are screwed together with LOW PROFILE 25mm screws.
MFCarew, MaryD, Mark Carew and 2 others like this.
