0-10v output issue
Discussion in 'Controller Boards' started by Rfleischgewehr, Nov 26, 2023.
  1. Rfleischgewehr
    Hello. I have a problem.
    The 0-10v doesn't work on my box.
    With the m3 s24000 command I have 0.30
    And with the m5 command to turn off the spindle I still have 0.3v
    Do you have an explanation?
    Thank you.
  2. Levi R
    Levi R New
    I have the same issue but I do get 0v after m5
  3. Levi R
    Levi R New
    did you also not power cycle it? that fixed it for me
    Thats fine. A properly set up vfd will stop at +-3.0v already (10x higher).
    Setup Min Freq on the VFD itself correctly. Usually for 120hz/7200rpm min
