1/4" shank drill bits? Anyone? How do you drill holes?
Discussion in 'CNC Mills/Routers' started by Ed Tschoepe, Nov 12, 2020.
  1. Ed Tschoepe
    I've been looking for a set of preferably short drill bits (imperial or metric) with a constant 1/4" shank for use on my CNC with my Makita RT0701C router. I'm amazed to find that such a thing doesn't seem to exist. I'm sure I could just plunge into aluminum with an end mill but that seems really wrong when a twist drill bit is designed for such an operation.
    I'm bootstrapping my homebrew machine by redoing the plates and I need to drill 5mm and 5.5mm holes in aluminum or garolite.
    Am I missing something? How do you folks drill holes when that's what's needed?
    Twist drills are for low-rpm, routers spin too fast.
    You get endmills that allow plunging (see Sharkbits on Openbuildspartstore.com) otherwise do ramping into the cut in your CAM software.
    Ed Tschoepe likes this.
  3. Ed Tschoepe
    Ahh, good point about the RPMs. I hadn't thought of that. 10,000 is way faster than they're designed for.
    My Z-axis is sloppy enough to where there is dangerous resonance (chatter) when I try to do helical operations in aluminum. That's why I'm redoing it. So my only option is to either
    1) use a V-carve bit to just mark the surface of the metal (accurately, or at least with consistent error) and then use a drill press or
    2) plunge into the metal with a proper end mill
    I'll look for end mills that are center cutting
    If you have slop, thats the one i'd recommend :)
  5. Ed Tschoepe
    Thanks, yeah, I was just coming to that same conclusion.
  6. Giarc
    I do not know what collets you have, but there are precision collets available for the Makita from Elaire Corp. I originally purchased the 1/8, 3/16, and the 1/4" set. I liked them so much that I bought the 4mm, 6mm, and 8mm set. This opens up a whole lot of endmill options. But if the slop is bad, marking and drilling is probably the most accurate. When I built my CNC I cut and drilled all the aluminum with power tools and a sander. To make sure the holes lined up on two corresponding plates, I clamped two aluminum plates together and drilled a coulple holes though the two and bolted them together. Then I drilled more holes and added enough bolts so the plates laid flat so I could cut and sand them to the template. It worked very well for me.
