1 of 2 Y axlies stops working.
Discussion in 'CNC Mills/Routers' started by Lewis Trafford, Feb 17, 2024.
  1. Lewis Trafford
    Hi all,
    I am having the above issue with my black box. 1 of the 2 Y axies stops working when the machine has been on for some time (around 45 minuets). I have checked that all the wiring to both of the Y stepper motors is OK.
    Once the BlackBox goes into this fault, I switched round the stepper motors to rule out it being a motor on the way out but the problem follows from the troubled output.
    Has anyone come across this before?
    Any help would be highly appriceated.
    #1 Lewis Trafford, Feb 17, 2024
    Lewis Trafford likes this.
  3. Lewis Trafford
    That sounds correct. Current set a bit high
  5. Lewis Trafford
    Peter, one more question - going off the document, with both of Y and Y2 turned all the way down, I am only able to stall one of the stepper motors (Y2), I increased until it couldn't stall Y2, looking into why I couldn't stall Y stepper I found that it is controlled via a 10k POT rather than 5k like the rest of the axies. Is this correct?
    Will check into it! Good catch, thanks
    @Lewis Trafford would you please contact the Store via Submit a ticket - we'd love to swop out that BlackBox for you - so we can investigate yours closer.
    Please include a link to this thread so they know what this relates to!
    Thanks for giving us the chance to sort it out for you!
  8. Lewis Trafford
    Hi @Peter Van Der Walt,
    I really appricate you looking into this for me, however, I have already made a purchase of the X32. Once I had ordered X32 I started to do some experimenting and soldered on a fixed 10k resistor to see if I could stall the stepper motor, with no sucess so I am guessing the controller had maybe over heated 1 to many times. Unfortunetly I have thrown away the old 10K POT. Had I of known you wanted the box back I wouldn't of touched it but not @'ing you in a post didn't help the matter.
    Thanks again! :)
    #8 Lewis Trafford, Feb 26, 2024
  9. Peter Van Der Walt
    Well glad to hear you are up and running! If you encounter any issues, let us know!
