1075 Sphinx
Discussion in 'CNC Mills/Routers' started by NeeqOne, Jun 22, 2018.
  1. NeeqOne
    NeeqOne Well-Known
    Thanks. I will get a very good square and tram the axes.
  2. GrayUK
    At least you have a nice square spindle to line up with. What size spindle are you using?
  3. NeeqOne
    NeeqOne Well-Known
  4. GrayUK
    I couldn't see from your photo which way you were running your Spindle, when leveling.
    1.5KW spindles are really quite heavy and it worries me that you might be getting twist on the X azis.
  5. NeeqOne
    NeeqOne Well-Known
    I was running pocketing along the X axis. That is what is worrying me too. I have put it up for sale. I will be downgrading to a 800W water cooled one.
    GrayUK likes this.
  6. ashish B
    ashish B New
    Did you ever resolve it ?
  7. NeeqOne
    NeeqOne Well-Known
    I have made some adjustment to my spindle. I will test the tomorrow and report back.
  8. NeeqOne
    NeeqOne Well-Known
    The Z and X are not perpendicular. I used some shims on the lower part of the spindle. However, it seems there are a bit bigger than need. I will try different shims and test again. The difference in heights between the layers are reduced drastically.
    GrayUK likes this.
  9. NeeqOne
    NeeqOne Well-Known
    I used one of my feeler gauge to adjust the spindle and tested it on another MDF. Results were much better this time.
