1510
Discussion in 'General Talk' started by Joseph Fitzmaurice, Apr 25, 2021.
  1. Joseph Fitzmaurice
    Hi I have a workbee 1510 belt drive and have upgraded the x axis with a leed screw what setting do I need to change in my black box software thanks as always joe
  2. sharmstr
    It depends on the size of the screw. If you go into the settings, there's a calculator next to the X steps per mn setting. Use that, save, then fine tune using the calibration wizard in wizards menu.
  3. Joseph Fitzmaurice
    It 8 mm same as the x axis
  4. sharmstr
    Then start with the same steps/mm setting. But make sure you also run the calibration wizard to compensate for difference in manufacturing tolerances.
    You mean Y right? X is already a leadscrew on the 1510
    If so,
    Set the Y axis steps per mm to 199.1 to start off:
    Click Save, and Reset when prompted
  6. Joseph Fitzmaurice
    No my openbuild 1510 was belt driven and I now have change the x axis to 8mm screw
    Ok, same as above but set 199.1 into the converted axis which is not currently 199.1
  8. Joseph Fitzmaurice
    Thanks i,s there any other settings I have to change like speed as the belt was much faster than screw joe
  9. Peter Van Der Walt
    Max rate and acceleration, compare with the other axis
