3d view doesn't match sheetcam view
Discussion in 'General Talk' started by Chris611, Dec 24, 2023.
  1. Chris611
    Chris611 New
    I'm using Sheetcam to nest parts for my plasma. I output the gcode as a .tap file. Then open it in Openbuilds Control. The 3d view shows parts interfering. I used nc viewer online and the parts don't touch. Why is the Openbuilds Control showing parts interfering? If I zoom way out, the start to spread apart and stop touching.
    Viewer shows the gcode you provide. Perhaps that GCODE isn't 100% Grbl Compatible. Arcs calculating incorrectly could indicate either wrong preferred type (Grbl prefers IJK not R) or incorrect decimals etc
    Or its offset in Z rotate the view and check from the side too
    #2 Peter Van Der Walt, Dec 24, 2023
  3. Chris611
    Chris611 New
    Ok. I'll look into that. Yesterday I nested about a dozen parts and it worked fine. Today I went to cut the rest and ran into this problem.
  4. Chris611
    Chris611 New
    I did some messing around. I think it's a perspective issue with the 3d viewer. I'm not sure why each part is on a different "layer." But I think that is causing the perspective view to make it appear that cuts are crossing each other. To test this, I re-ordered the parts left to right so they were closer spaced in the z axis and it kept the cut lines from appearing to cross in the 3d viewer.
      File size:
      24.8 KB
      66
    Figured yes. Your job has weird Z offsets. Fix that in CAD/CAM before generating gcode
  6. Chris611
    Chris611 New
    ok. I'll look into that. Here is the g-code that I'm using. Cut with it this morning and it worked.
