4040 pro
Discussion in 'CNC Mills/Routers' started by mESTEP1, Feb 24, 2025.
  1. mESTEP1
    mESTEP1 New
    4040 pro using candle bit not stepping down plunging through material. I have checked setup parameters still same issue ?
    not really enough to go on here....
    same issue as what?
    'not stepping down' and 'plunging through material' seem to need more words between them.
    How did you generate the Gcode? what is is supposed to be doing?
    Please upload the Gcode so we can look at it.
