6 wheels versus 4 on C-Beam Y axis
Discussion in 'CNC Mills/Routers' started by JayMcD, Dec 5, 2020.
  1. JayMcD
    JayMcD New
    Hi, I built a C-beam style cnc (500mmx500mm) with the y axis driven with lead screws , c beam gantry plate on one ( outer) side of the cbeam with 4 wheels. Contemplating making this 6 wheels and wondering if folks had any comments/thoughts. I think it would provide better support but also ore drag.They are being driven by nema 17 motors currently. Thanks
  2. Christian James
    Christian James Journeyman
    The 1010 workbee for example has 4 wheels on top. I found that unnecessary and worse still, very difficult to get all wheels evenly loaded. I changed to a 3 wheel system on top (centre wheel adjustable), while the LEAD machine I believe has a 2 wheel system. Trying to balance the load on 6 wheels would be a nightmare, and you only have a small machine. Nema 17's, are not really a good choice either.
    What I'm not sure about is what you actually have? Are you saying you have only one row of wheels running on the outer side of the C beam and none on the inner - not in tandem like is normal?
  3. JayMcD
    JayMcD New
    Sorry, my bad for not being clear. I meant 6 wheels total ( 3 top / 3 bottom) .thanks for your reply.
