A axis will only rotate one way with soft limits enabled
Discussion in 'CNC Mills/Routers' started by Fastbass, Nov 3, 2024.
  1. Fastbass
    Fastbass New
    Doing a 2 sided job with rotary axis flipping part 180 degrees, with soft limits enabled and A axis zeroed at the start of the job, when program calls for 180 degree rotation a axis rotates in negative direction and rotates continuous, not stopping at 180. It will not rotate positive with soft limits enabled, say unable to jog A+, will hit soft limits. so the DRO for A axis will only read in negative values, no way to get it to rotate positive. Any advise would be wonderful. X32 controller, I forgot to mention that sorry.
    Set A-axis Max Travel to "-1" to allow it unrestricted rotation. Normally only positive moves are in the machine envelope, to use negative spin (or outside 0-359deg either direction) with soft limits set A Axis Max Travel to -1
  3. Fastbass
    Fastbass New
    Thanks Peter!!!!!
  4. Fastbass
    Fastbass New
    it wont allow me to put in -1, says only excepts positive values and defaulted back to 360
  5. Fastbass
    Fastbass New
    you were talking about $133 correct?
    Will have to check the docs again, but perhaps its 0 instead of -1 that disables it.
  7. Fastbass
    Fastbass New
    I set $133 to 0 and it let me rotate axis positive and negative.... zeroed A axis and started job, 1st movement is to rotate axis 180 degrees, it started rotating and did not stop, had to stop job, here is the interesting part, rotated axis negative to get back to zero point, got to zero now it wont rotate positive due to soft limits. perplexing to say the least, so there are 2 issues at play here i think 1: it wont stop axis at gcode coord. and 2nd is the issue of not rotaing positive with soft limits enabled. It wont stop at programmed coord with soft limits enabled or disabled if that is helpful. Thanks in advance.
    Might be best to ask here https://github.com/grblHAL/core/issues
