Accuracy question
Discussion in 'Control Software' started by Javalin, Sep 12, 2023.
  1. Javalin
    Javalin New
    Hi
    Had a quick surf on the forum, but nothing obvious came up.
    (new) Openbuilds X32 controller with a (slightly smaller) Lead 1010 machine. Calibrates perfectly (200 steps per mm) on X & Y using the software. Bit size is correct (1/4 comes out at 6.25mm, so very close). A 20mm x 20mm pocket in Vectric produces the correct G-Code (openbuilds grbl mm post proc) but only a 19.3mm box when cut.
    No obvious play in the machine.
    Puzzled! Anybody any pointers?
    thanks in advance
    James
    Off in both direction by the exact same error? X and Y?
    if so, do post the gcode please
  3. Javalin
    Javalin New
    Hi Peter - yes nearly same error in both, I think Y is 19.5mm or so. Code spaced for readability. Vectric was set to a 1/4" bit at 6.25mm. 6.875mm+(6.25mm/2) = 10.00mm.
    thanks!
    Code below:
    Code:
    T1
    G17
    G21
    G90
    G0 Z20.320
    G0 X0.000 Y0.000
    M3 S15000
    G4 P1.8
    G0 X-1.875 Y-1.875 Z5.080
    G1 Z-1.500 F254.0
    G1 X1.875 F1100.0
    G1 Y1.875
    G1 X-1.875
    G1 Y-1.875
    G1 X-4.375 Y-4.375
    G1 X4.375
    G1 Y4.375
    G1 X-4.375
    G1 Y-4.375
    G1 X-6.875 Y-6.875
    G1 X6.875
    G1 Y6.875
    G1 X-6.875
    G1 Y-6.875
    G0 Z5.080
    M5
    G0 Z20.320
    G0 X0.000 Y0.000
    M2
  4. Christian James
    Christian James Journeyman
    If you actually entered a bit size of 1/4" into Vectric (and you say the actual bit diameter is close to 6.25mm), then that is why it undercuts. That's why it's important to accurately measure a bits size before "camming".
  5. Javalin
    Javalin New
    apologies if not clear in the post, the bit is a 1/4" but measures & cuts as 6.25mm which was entered into Vectric. Either way 2x0.1mm does not add up to 0.7mm
  6. Alex Chambers
    Please re-check your calibration - the pdf in the link below explains the theory, the video describes the calibration wizard in Openbuilds Control - that makes it easier by doing the sums for you, but calibrate over the longest distance you can accurately measure.
    Conventional milling and climb milling produce slightly different results because of tool deflection, so please do experiment with both
    The material you are cutting can also have an effect - very soft materials (like mdf) can be pushed away from the bit instead of cutting.
    For most accurate results it's always better to leave a small amount of stock for a full depth finishing pass (separate toolpath with most cam/controller set ups).
    Calibrating your cnc
  7. Javalin
    Javalin New
    the only think I can think of is that its skipping steps under load? tbh this is a 1.5mm deep cut at 1100mm/min in ply, so shouldn't be hardwork?
  8. Javalin
    Javalin New
    thanks Alex, will check again tonight. Tried a 1/8" bit first, and switched to a (nominal) 1/4" bit to rule out deflection issues.
  9. Alex Chambers
    If it's a profile or pocket cut and still lines up when it's gone all the way round you are not skipping steps - once you have missed a step you don't get it back again :)
    Javalin and Peter Van Der Walt like this.
    Our official number is 199.1 - its a rolled screw, precisely 200 is theoretical, but unlikely to be correct.
    Was there a change in error rate between bit sizes? Same percentage of error, or same error?
    If the error is still the same millimeters out - its machine calibration/tramming/something in the motion setup. If you cut a pocket twice the size, then we expect the error to double up as well
    Alex Chambers likes this.
  11. Javalin
    Javalin New
    Right. I understand the story now....
    TLDR; the test piece was bending just a little bit
    So this started with issues with mach3 controller being weird, so replaced with X32. All good. The new test piece of scrap wood was long and fairly thin, with it appears enough to account for a 1/2mm of accuracy when not screwed down in the middle too (doh!). The 199.1 steps/mm is spot on (i'd changed it).
    Oddly a 5mm slot still comes out at 4.7mm or so, but as a 192mm oval comes out at 192mm, I think thats more to do with bit deflection and wood compression.
    Thanks Peter and Alex for your help. Really appreciated. I think that's probably why people come (back) to OpenBuilds, good products and good customer support!
