Acro Y axis not working properly?
Discussion in 'General Talk' started by DaveySLP, Feb 1, 2022.
  1. DaveySLP
    DaveySLP New
    Hi, just got a new acro, had some problems with motor power, but managed to sort that issue out. However, having a very weird issue with Y axis movement...
    So when I fired the machine up, the Y axis motors were moving in opposite directions. No problem, I took the Y Dir jumper off, but now, they move in the same direction if I press the Y+ in the OB's control interface, but oppositely again if I go Y-? This makes no sense to me at all. I have even tried the invert Y axis in the grbl settings, still the same thing?
    Any help is greatly appreciated as I have no working machine until I can figure out what heck is going on here :)
    No, jumper has to be in place: See docs:blackbox:jumper-slaveaxis [OpenBuilds Documentation]
    If one motor is going the opposite way of its paired motor, its wiring of the motor itself - swop the wiring around (1-2-3-4 become 4-3-2-1) to correct. See the Acro wiring video for details
  3. DaveySLP
    DaveySLP New
    Hi Peter, OK I will try that, but I'm not sure how that explains why it syncs in one direction but not the other?
    Because you removed the jumper - now its not getting any direction signal. So it has no idea when to reverse. Put the jumper back. Then fix the motor wiring :)
  5. DaveySLP
    DaveySLP New
    Ok cool, that works fine now, thank you :).
  6. DaveySLP
    DaveySLP New
    Thank you Alex and Peter for your help and attention :)
