Adding a 4th Limit switch to Blackbox possible?
Discussion in 'CNC Mills/Routers' started by CNC_whittler, Oct 21, 2023.
  1. CNC_whittler
    If I wanted to add a 2nd limit switch on the Y; is it possible with the Blackbox? I have the older one, not the X32.
    I know it only has 1 each XYZ plugs on the Blackbox. Can I wire two limit switches into one plug and will it work?
    I'm running a Workbee 1010 if it matters...
    Thanks in advance!
    CNC_whittler likes this.
  3. CNC_whittler
