Adjusting Ecentric to create tension to wheels.
Discussion in 'CNC Mills/Routers' started by Wendel Clement, Apr 3, 2023.
  1. Wendel Clement
    Hello, I’m building a new 1515 but I am struggling to get all wheels to lock tight when adjusting the Ecentric nuts on all of my gantry’s. There is usually one or two which do not lock tight. Been tinkering with this for two days.
    Any guides or suggestions?
    mike dauteuil likes this.
  2. Alex Chambers
    They shouldn't be overtightened - you should JUST be able to turn a wheel with your finger.
    You also have a small amount of adjustment with the screws holding the wheels - if a wheel is still loose after adjusting the eccentric try loosening the eccentric fully, slacken the screw holding that wheel, push it firmly against the V-slot as you re-tighten the screw, then adjust the eccentric again.
  3. Wendel Clement
    Thank you for the reply. But is it possible to now do loose the Ecentric nuts and re attempt to tighten with the lead screw in and the gantry already assembled to the frame?
  4. Alex Chambers
    If you can get at the screws and nuts holding the wheels then you can try the trick I suggested - it's the wheels without the eccentrics that you should adjust.
  5. Wendel Clement
    So doing this…”slacken the screw holding that wheel, push it firmly against the V-slot as you re-tighten the screw, then adjust the eccentric again.” relates to the wheels without the Ecentric?
  6. Alex Chambers
    Yes. Do those first. If that doesn't provide enough adjustment try the ones with the eccentrics.
    Giarc likes this.
  7. Wendel Clement
    Amazing advice. Thank you so much.
  8. mike dauteuil
    Having the same loose wheel issue on my 1515.Made several attempts at squeezing
    the wheels into the slot. Still loose. Will drill out holes in the plates slightly oversized this weekend. That
    should give me enough room to get some contact with the rail. Several wheels are
    free spinning.
    #8 mike dauteuil, Aug 16, 2023
  9. Peter Van Der Walt
    Should not be needed and would likely make it even harder to tighten
    Make sure the opposite fixed side wheels are correctly installed - pushed inward before tightening to ensure the bolt shoulder is tight against the inside edge of the hole
    Then adjust Eccentrics according to
  10. Wendel Clement
    Amazing, thank you.
  11. mike dauteuil
    The x axis is the most concerning,
    3 of the 4 bottom wheels on the x dont touch the rail,no matter how much adjusting I do.
    I will tear it down this weekend.
  12. mike dauteuil
    After some squeezing and tweeking I got all but 1 wheel set. I'm going to leave it as is for now,
    run some test cuts in the morning.
    Giarc likes this.
