advice needed 7510 workbee
Discussion in 'CNC Mills/Routers' started by tankproof2, Nov 26, 2020.
Tags:
  1. tankproof2
    Hi guys, i dont know if this is the right place to ask this but could i have some advice on my first build.
    i am planning to buy a 750x1000mm mechanical kit off of ali express (https://www.aliexpress.com/item/3291...c00pATS93&mp=1) only because i think its the cheapest way to get a reasonable frame but maybe im wrong?
    i then plan to swap out the x and z axis to linear rail (off ali) for around 150£
    as far as motors go i am thinking 60BYGH401-03 because they are cheap and seem to have reasonably low inductance along with this i am thinking 48v and CW8060 drivers but maybe there are better available?
    i dont know on the controller yet so some advice would be awesome
    spindle. i don't really know with this one, i have read some good things about the G-Penny 2.2kw one (https://www.aliexpress.com/item/3225...c00pATS93&mp=1) it seems cheap ish and gets pretty good reviews. at the same time i don't know how good it really is so maybe someone can recommend me something better.
    i have found multiple options for a few things and would like to ask which is best
    spindle- they are all around the same price but with different vfds but which is the best?
    https://www.aliexpress.com/item/3225...c00DrQIm1&mp=1
    https://www.aliexpress.com/item/3298...c00DrQIm1&mp=1
    https://www.aliexpress.com/item/4000...c00DrQIm1&mp=1
    steppers i am thinking nema 23 and these are the options i have found which is the best?
    https://www.welectron.com/JMC-iHSV57...ed-Servo-Motor (this one comes with integrated drivers but is about the same cost as the other with a CW8060 driver)
    https://www.cnc4you.co.uk/Stepper-Mo...H401-03-Nema23
    drivers-
    i am thinking of going for a way over kill driver to give me head room for new/ more powerful motors
    options are the cw8060 https://www.aliexpress.com/item/6127...archweb201603_
    or cheap out and get some https://www.aliexpress.com/item/3291...c00DrQIm1&mp=1
    my question is what is the best cheap stepper right now?
    as far as voltage goes i am thinking 48v but is this too high?
    ohh almost forgot. i plan to cut mostly aluminium and some occasional Delrin
    let me know if you need anymore details thanks for any advice in advance Tank!
