Advice on End Mills
Discussion in 'CNC Mills/Routers' started by Brisruss, Sep 17, 2023.
  1. Brisruss
    Brisruss New
    I am just getting started and was wondering what end mills you use most. I am looking to do mostly wood with some occasional aluminium. Are the cheaper sets worth getting or do you get what you pay for?
    What does your basic starter set consist of?
    Russ
  3. Giarc
    I love the Openbuilds Down-Cut 2 Flutes Solid Carbide End Mill 1/4" end mill for wood working, but as Peter said, but a couple cheaper ones to get started with. Also, don't accidentally use the downcut if you are cutting aluminum like I did. It is an expensive mistake. I also have one of the sign making kits.
    I bought a bowl cutting bit form Spe tools (OpenBuilds needs to add a bowl bit to their catalog) and it worked well for this project. I used the OpenBuilds 1/4 downcut for the profile cut on this project.
  4. Brisruss
    Brisruss New
    Thanks Peter. That is exactly what I wanted to know. My only problem is I am in Australia so a bit of a wait for items shipped from O/S.
    Russ
  5. Brisruss
    Brisruss New
    Hi Craig,
    Thanks for replying. I imagine I will make some silly mistakes as I go along.
    Cheers Russ
  6. David the swarfer
    plenty of suppliers in Australia, use the OB page to figure out what you want, then look for it in-country.
