Alarm 8 Homing fails
Discussion in 'CNC Mills/Routers' started by Keld Daugaard, Dec 15, 2024.
  1. Keld Daugaard
    Hi everone
    I got at used Ratrig 750x750 with X32 Blackbox controller.
    When i will home it , comes up with Alarm 8 on the switches.
    Can i be a High freq problem even tho, I don't have anything high freq running?
    Edit: Can se that there is alot, that makes EMI.
    I'm also not sure how to set softlimits, I have set in the max in setting, but that does not seems to work proberly. Can't figure out where to set it other than #130 and #131
    The inductive sw are working fine when jogging.
    Can someone enlighten me?
    "General": {
    "General": [
    "id": "10",
    "label": "Status report options",
    "value": "511"
    "id": "11",
    "label": "Junction deviation",
    "value": "0.020"
    "id": "12",
    "label": "Arc tolerance",
    "value": "0.002"
    "id": "13#0",
    "label": "Report in inches",
    "value": "0"
    "id": "28",
    "label": "G73 Retract distance",
    "value": "0.100"
    "id": "32",
    "label": "Mode of operation",
    "value": "0"
    "id": "39#0",
    "label": "Enable legacy RT commands",
    "value": "1"
    "id": "62#0",
    "label": "Sleep enable",
    "value": "0"
    "id": "63",
    "label": "Feed hold actions",
    "value": "2"
    "id": "64#0",
    "label": "Force init alarm",
    "value": "0"
    "id": "384#0",
    "label": "Disable G92 persistence",
    "value": "0"
    "id": "396",
    "label": "WebUI timeout",
    "value": "30"
    "id": "397",
    "label": "WebUI auto report interval",
    "value": "0"
    "id": "398",
    "label": "Planner buffer blocks",
    "value": "35"
    "id": "481",
    "label": "Autoreport interval",
    "value": "0"
    "Control signals": {
    "Control signals": [
    "id": "14",
    "label": "Invert control pins",
    "value": "0"
    "id": "17",
    "label": "Pullup disable control pins",
    "value": "0"
    "Limits": {
    "Limits": [
    "id": "5",
    "label": "Invert limit pins",
    "value": "7"
    "id": "18",
    "label": "Pullup disable limit pins",
    "value": "0"
    "id": "20#0",
    "label": "Soft limits enable",
    "value": "0"
    "id": "21",
    "label": "Hard limits enable",
    "value": "1"
    "Coolant": {
    "Coolant": [
    "id": "15",
    "label": "Invert coolant pins",
    "value": "0"
    "Spindle": {
    "Spindle": [
    "id": "9",
    "label": "PWM Spindle",
    "value": "1"
    "id": "16",
    "label": "Invert spindle signals",
    "value": "0"
    "id": "30",
    "label": "Maximum spindle speed",
    "value": "24000.000"
    "id": "31",
    "label": "Minimum spindle speed",
    "value": "0.000"
    "id": "33",
    "label": "Spindle PWM frequency",
    "value": "400.0"
    "id": "34",
    "label": "Spindle PWM off value",
    "value": "0.0"
    "id": "35",
    "label": "Spindle PWM min value",
    "value": "0.0"
    "id": "36",
    "label": "Spindle PWM max value",
    "value": "100.0"
    "Tool change": {
    "Tool change": [
    "id": "341",
    "label": "Tool change mode",
    "value": "0"
    "id": "342",
    "label": "Tool change probing distance",
    "value": "30.0"
    "id": "343",
    "label": "Tool change locate feed rate",
    "value": "25.0"
    "id": "344",
    "label": "Tool change search seek rate",
    "value": "200.0"
    "id": "345",
    "label": "Tool change probe pull-off rate",
    "value": "200.0"
    "id": "346#0",
    "label": "Restore position after M6",
    "value": "1"
    "Homing": {
    "Homing": [
    "id": "22",
    "label": "Homing cycle",
    "value": "1"
    "id": "23",
    "label": "Homing direction invert",
    "value": "4"
    "id": "24",
    "label": "Homing locate feed rate",
    "value": "100.0"
    "id": "25",
    "label": "Homing search seek rate",
    "value": "1000.0"
    "id": "26",
    "label": "Homing switch debounce delay",
    "value": "250"
    "id": "27",
    "label": "Homing switch pull-off distance",
    "value": "10.000"
    "id": "43",
    "label": "Homing passes",
    "value": "1"
    "id": "44",
    "label": "Axes homing, first pass",
    "value": "4"
    "id": "45",
    "label": "Axes homing, second pass",
    "value": "3"
    "id": "46",
    "label": "Axes homing, third pass",
    "value": "0"
    "Probing": {
    "Probing": [
    "id": "6#0",
    "label": "Invert probe pin",
    "value": "1"
    "id": "19#0",
    "label": "Pullup disable probe pin",
    "value": "0"
    "id": "65#0",
    "label": "Probing feed override",
    "value": "0"
    "Jogging": {
    "Jogging": [
    "id": "40#0",
    "label": "Limit jog commands",
    "value": "0"
    "Networking": {
    "Networking": [
    "id": "70",
    "label": "Network Services",
    "value": "7"
    "id": "300",
    "label": "Hostname",
    "value": "Grbl"
    "id": "302",
    "label": "IP Address",
    "value": "192.168.5.1"
    "id": "303",
    "label": "Gateway",
    "id": "304",
    "label": "Netmask",
    "value": "255.255.255.0"
    "id": "305",
    "label": "Telnet port",
    "value": "23"
    "id": "306",
    "label": "HTTP port",
    "value": "80"
    "id": "307",
    "label": "Websocket port",
    "value": "81"
    "WiFi": {
    "WiFi": [
    "id": "73",
    "label": "WiFi Mode",
    "value": "1"
    "id": "74",
    "label": "WiFi Station (STA) SSID",
    "value": "Kaelder"
    "id": "75",
    "label": "WiFi Station (STA) Password",
    "value": "********"
    "Aux ports": {
    "Aux ports": [
    "id": "370",
    "label": "Invert I/O Port inputs",
    "value": "0"
    "Stepper": {
    "Stepper": [
    "id": "0",
    "label": "Step pulse time",
    "value": "10.0"
    "id": "1",
    "label": "Step idle delay",
    "value": "255"
    "id": "2",
    "label": "Step pulse invert",
    "value": "0"
    "id": "3",
    "label": "Step direction invert",
    "value": "4"
    "id": "4",
    "label": "Invert stepper enable pin(s)",
    "value": "0"
    "id": "8",
    "label": "Ganged axes direction invert",
    "value": "0"
    "id": "29",
    "label": "Pulse delay",
    "value": "5.0"
    "id": "37",
    "label": "Steppers deenergize",
    "value": "0"
    "X-axis": {
    "X-axis": [
    "id": "100",
    "label": "axis travel resolution",
    "value": "199.100"
    "id": "110",
    "label": "axis maximum rate",
    "value": "2500.000"
    "id": "120",
    "label": "axis acceleration",
    "value": "150.000"
    "id": "130",
    "label": "axis maximum travel",
    "value": "744.000"
    "Y-axis": {
    "Y-axis": [
    "id": "101",
    "value": "199.100"
    "id": "111",
    "value": "2500.000"
    "id": "121",
    "value": "150.000"
    "id": "131",
    "value": "755.000"
    "Z-axis": {
    "Z-axis": [
    "id": "102",
    "value": "199.100"
    "id": "112",
    "value": "2500.000"
    "id": "122",
    "value": "150.000"
    "id": "132",
    "value": "90.000"
    #1 Keld Daugaard, Dec 15, 2024
    Full logs and screenshots helps. We don't always know every code off the top of our heads. The text onscreen helps a lot more, tells you exactly whats wrong actually
  3. Keld Daugaard
    Yes i know.
    I tried to use Gsender, that helped a little.
    It's a little tricky, it's a new maskine and controller to me, so there is a learning curve.
    If it has random failures & and I'm new to that system, then is not easy.
    I'll se if i can load screen shots and logs up later.
    I'm use to run Mach 3-
    EDIT: It's working now, #5 should be 0, and not 7 on this mashine.
    #3 Keld Daugaard, Dec 15, 2024
  5. Keld Daugaard
