Hi all! When I do the auto probe thing, it starts with the Z, then X then Y... but, at Y, it happens 2 out of 5 times that even if the light is on, it continues to push (Y+), anyone already had that issue? Thanks
it was on the collet nut. but if the light of the xyz probe was opened, it was supposed to be stopped isn't it?
If I understand it correctly, the led works off the ground and V+ wires. So, check for a loose signal wire. docs:xyzprobe:wiringtoblackbox.png [OpenBuilds Documentation]
