Hello.Iam using the black box controller.I would like to add the automatic tool setter,sensor.To measure the tools atomatical.Is there any way to connect the sensor to the black box controller.There are few on the aliex.Also i would need to make a macro for that right?Thanks.
Find a Normally Open sensor and wire it to the Probe port yes. Then see Getting started with Javascript Macros in CONTROL / Library of Macros created by the community
Same, just set $6=0 or $6=1 respectively (Use troubleshooting tab to confirm). Just eliminates the possibility of using a touch off and normally open material probe like ours in parallel unfortunately.
