axis calibration
Discussion in 'OpenBuilds Bug Report' started by Kimon Ioannidis, May 16, 2023.
Tags:
  1. Kimon Ioannidis
    Hello everyone
    I have built a fixed gantry router
    I'm in the final stages of tuning it up
    At present I have a problem with setting up the movement on all three axes
    When I input a travel movement of 100 to the wizard it only moves 50, when I enter this value to allow it to calculate the correct steps per mm and then issue a specific distance to move, it's always way off.
    when I tell the wizard I'm using a direct coupled 1605 5mm lead screw, 1/8 micro steps, 1.8 deg. and save this data, the next time that I call up the step calculator parameters it reverts to displaying an acme thread with a 20 tooth pulley.
    What can I do to force the software to accept my specific data
    thanks
    regards
    Kim
    Make sure your acceleration/max rate is set low enough to not stall. Stalling during the move will affect calibration
    Also make sure its not mechanical (slipping shaft couplers)
    That's just a calculator to help you figure out the Steps per mm
    Nowhere does it need to save what type of drive system you have, it just calcs the steps and puts that into the steps per mm field
  3. Kimon Ioannidis
    Apparently on my last try after restarting the computer and all, I was able to tune the x and y axis and will do the same for the
    z after correcting an issue with its lower limit switch.
    regards
    kim
