Axis motor stops mid-Job
Discussion in 'OpenBuilds Bug Report' started by Russell D Teubert, Mar 1, 2023.
  1. Russell D Teubert
    I have had my WorkBee 1010 with Blackbox for over 2 years with very little problem. Lately, it has stopped running one of the motors- X, Y, or Z - sometimes mid-job!
    Initially I thought it was a wiring issue, so I would disconnect, remove power and check the wiring- tightening the screws or stripping and reconnecting the ends to the motor. Then it would function normally. I just figured out that simply turning it off & on again will "reset" it and it functions again for a time- although the functional time is getting shorter and shorter.
    Any thoughts or similar experiences out there?
  3. Russell D Teubert
    No Fault LED. I'll get to cleaning.
    Thank you!
    If the FAULT LED does not light its probably not overheating, but still a little maintenance doesn't hurt. Check the fan too
    Or perhaps you've not noticed the LED, if so, keep an eye out next time it happens
