Bad results
Discussion in 'OpenBuilds Forum Help' started by Bilrob, Jan 27, 2025.
  1. Bilrob
    Bilrob New
    Hi guys,
    Wondering if this is the result of bad adjustements on speeds, feeds, ect or my LEAD1010 needs to be adjusted?
    Take a close up pic of the endmill from the cutting face end please, and tell us what your pass depth and stepover was
  3. Misterg
    Misterg Veteran
    In addition to Peter's request:
    What program did you use for the CAM (to generate the GCode)?
    What operation(s) did you use for the machining process?
  4. Bilrob
    Bilrob New
    Hi Peter, it was exactly that, I had a compression bit on. Ajusted the depht of the cut accordingly, set a 20% stepover and the results are way better. Thanks.
    Peter Van Der Walt and Misterg like this.
  5. Bilrob
    Bilrob New
    Thanks Misterg also.
    Misterg likes this.
