Best Bits, feeds, and Speeds for Plywood
Discussion in 'CNC Mills/Routers' started by Scott Thompson, Jul 17, 2021.
  1. Scott Thompson
    Hi Everyone,
    To date I have been experimenting with cuting only MDF on my Lead 1010. Last night I tried to cut plywood with horrible results; terrible top and bottom layer break out, rough cutting edges, etc. I have tried both up and down cut bits and the results are still a mess. Any suggestions?
    Thanks,
    Scott
    Is the plywood of a suitable grade? The $20/sheet stuff around here is held together barely, and has massive voids flooded with resin. Cutting that results in tears only. The better furniture grade plywood has better lamination and doesnt break up, cuts cleanly
  3. Scott Thompson
    Yes the grade is good to excellent. Got a few ends cuts from the local mill to experiment with.
  4. Alex Chambers
    Make sure that the plywood is held down. Use an upcut, but leave some stock to clear with a finishing path. Do the finishing path full depth with a compression (combined up&downcut) bit.
  5. Gary Caruso
    I've had good results with straight flute bits, sharp is key, and don't cut too much in one go, or chatter will happen. Keep to about 1x of bit diameter for depth of cut.
    The down cut SharkBite's from Openbuilds are excellent.
    Compression bit finish pass is great if you can.
    Pics of your issue could help us see what your problem is.
    Gary
    Kiskovce likes this.
