Bit Chatter only when moving in the Y+ direction
Discussion in 'CNC Mills/Routers' started by Ethan Maloy, Jan 18, 2025.
  1. Ethan Maloy
    Need some help finding the cause of my bits chattering only in the Y+ direction (no chatter in the Y- direction).
    I have a fresh Freud 75-102 upcut bit. I am running at 12000 rpm, 1200 mm/s feed, (.05 mm chip load) with a 40% step over, and 0.125" pass depth. Climb cutting.
    I have made sure my back lash is set correctly.
    I tested a conventional cut and this lead to chatter in the x+ direction, and no chatter in the x- or y directions.
    What can I do to eliminate this chatter?
  2. Ethan Maloy
    Update for anyone who finds this thread later, I was digging through another CNC forum and found that if your Router is placed with the majority of the body below the mount/clamp you can create a level leading to chatter.
    Simple fix, have less of your router hanging below the mount.
  3. Giarc
    I use two mounts. One up towards the top and one at the tool end. It works great for me.
    Ethan Maloy likes this.
