Black box and servo
Discussion in 'Controller Boards' started by crashradius, Jun 4, 2024.
  1. crashradius
    Greetings
    I have a Blackbox which has a servo port. I would like to activate the servo, but when I go to the wizard to switch it to 2 Axis and servo. That choice is not there. What to
    BlackBox 4X or BlackBox X32?
    The tools for the older one is no longer available, you would have to flash manually
  3. crashradius
    Its a 4X
  4. crashradius
    And how do I do this
    Disconnect CONTROL from the device
    1) Download the attached file and extract it
    2) Download xloader https://github.com/binaryupdates/xLoader/archive/refs/heads/master.zip and extract it
    3) Run xLoader.exe from inside the extracted folder
    • Hex File: pick the grbl-servo-nodoor.hex you extracted in (1)
    • Device: Uno(ATmega328)
    • COM Port: Select your correct port
    • Baud rate: 115200
    • Click Upload
