I recently upgraded my Millright Carve King with an Open Builds Black Box. I have used the Open Builds CAM before and I like it. However, since installing the Black Box, when I reset my zero for any of the axis, it doesn’t change the coordinates visually. Any suggestions?
Are you using OpenBuilds CONTROL? Did you use our CUSTOM.machine profile so the Reporting Options are set correctly?
Grbl Settings backup for review? (Suspecting you don't have $10=511 as set by our profiles) Also make sure to update BlackBox firmware docs:blackbox-x32:firmware [OpenBuilds Documentation]
