Black box Troubles.
Discussion in 'CNC Mills/Routers' started by Rod13, Oct 27, 2020.
  1. Rod13
    Rod13 New
    I had my Black box for a couple of weeks now. I receive an email about moving the pin setting from auto to UBS. But before I did that, (forgot about the email) I ran a gcode file and after it finish it disconnect. Now unable to connect. I Then I remember the email and switch it but still will not connect. I have a flashing red light. and it says the port is closed. Is there something I can do or is it under warranty. Stuck with a project and need advise.
    Rod
    http://support.openbuilds.com/support/home will happily sort you out :)
  3. Rod13
    Rod13 New
    Thank you for the reply form sent.
