Black Box X 32 E-Stop
Discussion in 'Controller Boards' started by njload, Dec 20, 2022.
  1. njload
    njload New
    How would I wire E-stop to the Black Box X 32? I've had to hit my X-controller E-stop more than once and like the safety net feeling of having one. Might be too late relying on the abort function in Control Software.
    Emergency stops should always cut POWER
    In case of a real emergency you don't want to depend on software (or even a switch wired to the controller, still subject to Firmware) and the issue might even be downstream from a controller. What if an overloaded power strip catches fire? Or the emergency is someone shocking
    Wall outlet > E-Stop > power strip > Everything else :)
    Easiest option: https://www.rockler.com/safety-power-tool-switch between the wall and your power strip
