Blackbox crashes when trying to home a second time with autosquaring enabled
Discussion in 'OpenBuilds Bug Report' started by isnie, Oct 15, 2024.
  1. isnie
    isnie New
    I have a Stronghold Pro with the BB 32. I recently changed the inductive switches that came with my machine to the Openbuilds limit switches to have auto squaring possibility.
    I flashed the BB 32 firmware with a build generated through http://svn.io-engineering.com:8080/?driver=ESP32&board=BlackBox X32 . When I start my machine and press the Home All button in the Control software my machine is homed and squared as expected. Everything else, like starting a job or jogging the machine works as well. However, if I press the Home All button again I get the following error and crash.
    Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
    Core 1 register dump:
    PC : 0x400dafb0 PS : 0x00060330 A0 : 0x800d8e5f A1 : 0x3ffb63a0
    A2 : 0x3ffb643c A3 : 0x3ffb6410 A4 : 0x3ffb6804 A5 : 0x3ffc3718
    A6 : 0x00000000 A7 : 0xc42feb33 A8 : 0x3ffb63ac A9 : 0x3ffb63ac
    A10 : 0x00000000 A11 : 0x3ffb6804 A12 : 0x00000014 A13 : 0x3ffc36dc
    A14 : 0x000124f8 A15 : 0xc42feb33 SAR : 0x00000007 EXCCAUSE: 0x0000001c
    EXCVADDR: 0xc42feb47 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0x00000000
    Backtrace:0x400dafad:0x3ffb63a0 0x400d8e5c:0x3ffb6410 0x400d91b3:0x3ffb64c0 0x400da511:0x3ffb64f0 0x400e3e2a:0x3ffb6530 0x400e3eb9:0x3ffb6550 0x400e4049:0x3ffb6570 0x400dbe3d:0x3ffb65b0 0x400d45f8:0x3ffb65f0 0x400d1e7f:0x3ffb6620
    ELF file SHA256: bdea617fefcb93fd
    CPU halted.
    I simply disconnect and reconnect and I can then home again. Any idea what is causing this?
    Inductives don't work so well in parallel. For autosquare we'd recommend Xtension Limit Switch Kit
    That does look like a firmware bug, so might want to report it here instead Issues · grblHAL/ESP32
  3. isnie
    isnie New
    Indeed, that's what I did after finding a topic on the subject matter on this forum.
    My limit switches are from the Xtension kit. Out of curiosity, how accurate/repeatable are these switches?
    I've opened a new issue on github.
    Thanks!
    Very good, definately better than inductives (they are temp sensitive - temperature rise affects the B(H) curve of the magnetic core, etc - not always very repeatable).
    Inductives only really better in being waterproof if thats a requirement for a particular build, but otherwise a lever switch is more precise.
