Blackbox Issue?
Discussion in 'Controller Boards' started by Ebon eben, Aug 4, 2020.
  1. Ebon eben
    Ebon eben New
    hello
    Have two problems with my BB first is that the fan will not spin up the second is that the Z errors about 10 mins in ( only tried some light text V carve) the austrilian maker store who sold it to me has stated that I need to contact Open builds for a fix. any thoughts or ideas to fix
    I’m 80% sure that the Z is an over heat due to no fan, I get the red !
    thank you
    #1 Ebon eben, Aug 4, 2020
    1) Check that your plugged the fan in with polarity correct (+ = red wire, - = black wire), and was it incorrectly plugged in at some point (reversing polarity on them can destroy them)
    2) Yes, red exclamation is indication of overheating. Turn the current down a little to avoid damaging the driver chip. http://support.openbuilds.com/support/home can assist with a replacement fan if needed (though you might be able to get a 60x60x10mm 24v fan locally next day off amazon or the like too, they are super cheap, and a lot quicker)
    Ebon eben likes this.
  3. Ebon eben
    Ebon eben New
    Thank you, I wired the fan correctly red on the +, had it check this arvoFan was dead. I have returned the box to the maker store here in OZ and will hopefully have a replacement in a week or so.
