blackbox/open builds control calibration??
Discussion in 'Controller Boards' started by baum, Oct 8, 2021.
  1. baum
    baum New
    Im at a loss. when I run the calibration wizard I get it spot on to the 100mm it moves. I go and jog it 100mm and it goes less than the amount i specify. See the attached pics. Doing this makes my intended designs off in size.
    pics are named for the steps i did. "calibration" is that, "jog" is that.
    my bb is "stock" 1/8 microstepping. I even left the pots at the default setting for the current on the motors.
    Any help would be great.
    Any 3rd party components?
    Adjusted Acceleration and Max rates down as a test yet?
    Adjusted jogging speed down from 100% as a test yet (too fast can stall, thus may need to tweak Max Rate)?
    Checked shaft coupler grub screws / shaft slippage yet?
  3. baum
    baum New
    Mechanically its good i looked those over. I will try and adjust the acceleration
  4. baum
    baum New
    I adjusted accelerations and jogs down and still moves short of the 100mm
    Go to Grbl Settings tab, click BackUp Settings and upload the settings backup .txt file here for an check
    Which of our machine do you have?
    Also please answer above ^
