Blackbox reset after streaming GCODE via serial
Discussion in 'Control Software' started by skimslozo, Aug 14, 2024.
  1. skimslozo
    skimslozo New
    Hi all,
    I'm streaming GCODE directly to my Blackbox X32 via serial in a small Python script. The serial port is opened, GCODE commands are streamed to it, and the serial port is closed on exit. Works fine on the first try, but if the script is restarted, it hangs on the first instance of ser.readline(). If the firmware is restarted via the reset button on the X32, it runs fine again on the first try.
    Any ideas on how to configure it such that no button-reset is required each time?
    Cheers,
    Miks
    Sample code below:
    class ControlBase(Node):
    self.rail_interface = '/dev/ttyUSB0'
    self.rail_baudrate = 115200
    self.ser = None
    self.ser = serial.Serial(self.rail_interface, self.rail_baudrate)
    def send_wake_up(ser):
    # Wake up
    ser.write(str.encode("\r\n\r\n"))
    time.sleep(2) # Wait for Printrbot to initialize
    ser.flushInput() # Flush startup text in serial input
    send_wake_up(self.ser)
    time.sleep(1)
    command = b'$X\n'
    self.ser.write(command)
    grbl_out = self.ser.readline() # Hangs here after script restart
    print(f"{command} : " , grbl_out.strip().decode('utf-8'))
    time.sleep(1)
    command = b'G91\n'
    time.sleep(1)
    command = b'G21\n'
    time.sleep(1)
    print("Rail initialized")
    self.ser.write(command) # GCODE written here asynchronously
    # Cleanup
    self.ser.flushInput()
    self.ser.flushOutput()
    self.ser.close()
    Might have to do with the opening/closing of the port. Maybe your code is not doing the DTR/RTS/CTS handshakes correctly: Play around with DTR disabled first, but for some configs and OS's we do add it back in too: OpenBuilds-CONTROL/index.js at deff1fad029c04ac0a7733f536f37ec1e3e3ba70 · OpenBuilds/OpenBuilds-CONTROL and OpenBuilds-CONTROL/index.js at deff1fad029c04ac0a7733f536f37ec1e3e3ba70 · OpenBuilds/OpenBuilds-CONTROL so best to build it out to handle different autoreset scenarios on port opening. We do have to cater for grbl and grblHAL, both our boards and 3rd party. USB to Serial chips and native USB - quite a mix so we try every handshake on connection before giving up
  3. skimslozo
    skimslozo New
    Thanks Peter!
    Played around with the DTR/RTS toggling on port opening, the following solved the issue:
    self.rail_baudrate,
    self.ser.dtr = False # Start with DTR low
    self.ser.rts = False # Start with RTS low
    time.sleep(0.5) # Wait a bit
    self.ser.dtr = True # Then set DTR high
    self.ser.rts = True # Then set RTS high
  4. David the swarfer
    arduino based GRBL resets on connect, grblHAL 'might' reset on connect.
