BlackBox + with Inductive Proximity Switch?
Discussion in 'Controller Boards' started by Arnaudvr, Mar 8, 2021.
  1. Arnaudvr
    Arnaudvr New
    Hello,
    With the Blackbox
    It's possible change the Xtension limit switch ?
    with Inductive Proximity Switch NPN NO DC 6-36V, 4mm Detecting Distance LJ12A3-4-Z/BX.
    Thanks Alot
    Have a nice day
    Yes you can. (but only one per axis, you cannot parallel Inductives, like you can with Xtension switches)
    Brown = V+,
    Blue = GND, and
    Black = SIG
    Check the voltage range of your inductives, if its 6-36v it may not run well off the default 5V supply, you can then refer to docs:blackbox:jumper-limitswitchvoltage [OpenBuilds Documentation] top power them off 24v instead
    ToddW and sharmstr like this.
  3. Arnaudvr
    Arnaudvr New
    Thanks Alot Peter.
    I go changing to 24v and try with 3 inductives limit switch.
    Regards
  4. Janne Gustafsson
    Did it work well with inductive switches? Are they less sensitive to EMF?
    With any EMI problem, its always best to address the source (rather than trying to make every little component around it immune, yet leaving the actual problem to keep spraying EMI out around it)
    Noisy spindle/router? Fix the earthing
    Dust hose building up static? Build a Swing Arm and throw a length of bare copper inside the hose
    Motor wiring crosstalking to the limits wiring? Get another cable chain for a couple bucks, add some spacing between the two sets of wiring.
    Fixing the source (where the noise is coming from) is the way to go.
    Further reading: docs:blackbox:faq-emi [OpenBuilds Documentation]
    Per-se Inductives are not more immune by the way.
