Blackbox x32 and interface touch with custom build help
Discussion in 'CNC Mills/Routers' started by Justin Brawley, Apr 15, 2024.
  1. Justin Brawley
    Maybe I did not look hard enough but where can I find information on how to hook up and run the x32 and the touch as I have built my own cnc router machine with a spindle. I Did watch one video of each on YouTube but I dont think it was very descriptive unless I missed something. The other question is do I still need to run the stepper drivers that came with the nema 23 stepper motor kit I bought off amazon?
  2. Giarc
    X32 hook-up: docs:blackbox-x32:start [OpenBuilds Documentation] and within those instructions you will find how to hook up the touch plate. Hopefully you used a 24V power supply for your build.
    If it came with a power supply (even if it is 24v) do not use it. Those cheap LED PSUs lack power filtering and cause damaging surges that will void the BlackBox warranty
    Check the motors electrical specs.
    Ours are
    3-6v coils, any higher and they will accelerate badly
    1-2mH Inductance, higher and they will have slow top speed due to self braking back-EMF
    1.7-3.0A current, higher will lower available torque.
    Work your way through BlackBox Documentation: https://docs.openbuilds.com/blackbox-x32
    Interface Documentation: https://docs.openbuilds.com/interface
    Also checkout the Software Overview docs:software:overview [OpenBuilds Documentation]
    Giarc and David the swarfer like this.
  4. Justin Brawley
    Thabks for the reply i am going to check this out now and Sorry I meant the cnc interface touch not the touch plate.
  5. Justin Brawley
    I bought the power supply from open builds as well
    Awesome then it will not be a problem
  7. Justin Brawley
    these are the kits I bought
    spindle
    Amazon.com
    Nema 23 (doesnt give me much info as far as voltage and current goes)
    Amazon.com
  9. Giarc
    This was the model number on his Amazon link: 23HS5628 Motor.
    Google provided this:
  10. Justin Brawley
    So according to that data sheet I should be good to run these motors with the openbuilds set up?
  11. Peter Van Der Walt
    Should work, higher inductance will be a little slower on Max Rate
  12. Justin Brawley
    2.5mh on these it was stated in this thread no higher than 2mh so will that be an issue
  13. Justin Brawley
    Thank you guys for the help by the way I do very much appreciate it
