BlackBox X32 GRBL error
Discussion in 'CNC Mills/Routers' started by John Tramell, Apr 12, 2023.
  1. John Tramell
    I just installed an X32 on my X-Carve this afternoon. When I installed it and tried to do XYZ homing operation, the cutter moved from the proper position over the XYZ Plus probe hole at the left front corner of the job and moved to the center of the wasteboard. I did an abort, and now the entire system has a repeating HARD LIMIT Stop error saying it needs to be homed before anything, but the system will not home. It keeps giving the same HARD LIMIT STOP ERROR. Here is a copy of the log,
    [16:48:21] [ $$ ] $7=0 ;Disable spindle with 0 speed, boolean
    [16:48:21] [ $$ ] $8=0 ;Ganged axes direction invert as bitfield
    [16:48:21] [ $$ ] $10=511 ;Status report options, mask
    [16:48:21] [ $$ ] $11=0.010 ;Junction deviation, millimeters
    [16:48:21] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
    [16:48:21] [ $$ ] $13=0 ;Report in inches, boolean
    [16:48:21] [ $$ ] $14=0 ;Limit pins invert, mask
    [16:48:21] [ $$ ] $15=0 ;Coolant pins invert, mask
    [16:48:21] [ $$ ] $16=0 ;Spindle pins invert, mask
    [16:48:21] [ $$ ] $17=0 ;Control pins pullup disable, mask
    [16:48:21] [ $$ ] $18=0 ;Limit pins pullup disable, mask
    [16:48:21] [ $$ ] $19=0 ;Probe pin pullup disable, boolean
    [16:48:21] [ $$ ] $20=0 ;Soft limits enable, boolean
    [16:48:21] [ $$ ] $21=1 ;Hard limits enable, boolean
    [16:48:21] [ $$ ] $22=1 ;Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
    [16:48:21] [ $$ ] $23=3 ;Homing direction invert, mask
    [16:48:21] [ $$ ] $24=100.0 ;Homing locate feed rate, mm/min
    [16:48:21] [ $$ ] $25=1000.0 ;Homing search seek rate, mm/min
    [16:48:21] [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
    [16:48:21] [ $$ ] $27=5.000 ;Homing switch pull-off distance, millimeters
    [16:48:21] [ $$ ] $28=0.100 ;G73 retract distance, in mm
    [16:48:21] [ $$ ] $29=0.0 ;Step pulse delay (ms)
    [16:48:21] [ $$ ] $30=1000.000 ;Maximum spindle speed, RPM
    [16:48:21] [ $$ ] $31=0.000 ;Minimum spindle speed, RPM
    [16:48:21] [ $$ ] $32=0 ;Laser-mode enable, boolean
    [16:48:21] [ $$ ] $33=5000.0 ;Spindle PWM frequency
    [16:48:21] [ $$ ] $34=0.0 ;Spindle off Value
    [16:48:21] [ $$ ] $35=0.0 ;Spindle min value
    [16:48:21] [ $$ ] $36=100.0 ;Spindle max value
    [16:48:21] [ $$ ] $37=0 ;Stepper deenergize mask
    [16:48:21] [ $$ ] $39=1 ;Enable printable realtime command characters, boolean
    [16:48:21] [ $$ ] $40=0 ;Apply soft limits for jog commands, boolean
    [16:48:21] [ $$ ] $43=1 ;Homing passes
    [16:48:21] [ $$ ] $44=4 ;Homing cycle 1
    [16:48:21] [ $$ ] $45=3 ;Homing cycle 2
    [16:48:21] [ $$ ] $46=0 ;Homing cycle 3
    [16:48:21] [ $$ ] $62=0 ;Sleep Enable
    [16:48:21] [ $$ ] $63=2 ;Feed Hold Actions
    [16:48:21] [ $$ ] $64=0 ;Force Init Alarm
    [16:48:21] [ $$ ] $65=0 ;Require homing sequence to be executed at startup
    [16:48:21] [ $$ ] $70=7 ;Network Services
    [16:48:21] [ $$ ] $73=1 ;Wifi Mode
    [16:48:21] [ $$ ] $74=John & Shari Home ;Wifi network SSID
    [16:48:21] [ $$ ] $75=JohnandShariHome ;Wifi network PSK
    [16:48:21] [ $$ ] $100=199.100 ;X-axis steps per millimeter
    [16:48:21] [ $$ ] $101=199.100 ;Y-axis steps per millimeter
    [16:48:21] [ $$ ] $102=199.100 ;Z-axis steps per millimeter
    [16:48:21] [ $$ ] $110=1500.000 ;X-axis maximum rate, mm/min
    [16:48:21] [ $$ ] $111=1500.000 ;Y-axis maximum rate, mm/min
    [16:48:21] [ $$ ] $112=1500.000 ;Z-axis maximum rate, mm/min
    [16:48:21] [ $$ ] $120=50.000 ;X-axis acceleration, mm/sec^2
    [16:48:21] [ $$ ] $121=50.000 ;Y-axis acceleration, mm/sec^2
    [16:48:21] [ $$ ] $122=50.000 ;Z-axis acceleration, mm/sec^2
    [16:48:21] [ $$ ] $130=750.000 ;X-axis maximum travel, millimeters
    [16:48:21] [ $$ ] $131=750.000 ;Y-axis maximum travel, millimeters
    [16:48:21] [ $$ ] $132=100.000 ;Z-axis maximum travel, millimeters
    [16:48:21] [ $$ ] $300=Grbl ;Hostname
    [16:48:21] [ $$ ] $302=192.168.5.1 ;IP Address
    [16:48:21] [ $$ ] $303=192.168.5.1 ;Gateway
    [16:48:21] [ $$ ] $304=255.255.255.0 ;Netmask
    [16:48:21] [ $$ ] $305=23 ;Telnet Port
    [16:48:21] [ $$ ] $306=80 ;HTTP Port
    [16:48:21] [ $$ ] $307=81 ;Websocket Port
    [16:48:21] [ $$ ] $341=0 ;Tool Change Mode
    [16:48:21] [ $$ ] $342=30.0 ;Tool Change probing distance
    [16:48:21] [ $$ ] $343=25.0 ;Tool Change Locate Feed rate
    [16:48:21] [ $$ ] $344=200.0 ;Tool Change Search Seek rate
    [16:48:21] [ $$ ] $345=100.0 ;Tool Change Probe Pull Off rate
    [16:48:21] [ $$ ] $370=0 ;Invert I/O Port Inputs (mask)
    [16:48:21] [ $$ ] $384=0 ;Disable G92 Persistence
    [16:48:21] [ $$ ] ok
    [16:48:21] [ $I ] [VER:1.1f.20220325:custom]
    [16:48:21] [ $I ] [OPT:VNSL2,35,1024,3,0]
    [16:48:22] [ $I ] [NEWOPT:ENUMS,RT+,HOME,TC,SED,WIFI,SD]
    [16:48:22] [ $I ] [FIRMWARE:grblHAL]
    [16:48:22] [ $I ] [NVS STORAGE:*FLASH]
    [16:48:22] [ $I ] [DRIVER:ESP32]
    [16:48:22] [ $I ] [DRIVER VERSION:220327]
    [16:48:22] [ $I ] [DRIVER OPTIONS:v4.3.2-555-gb4ef1b80a2-dirty]
    [16:48:22] [ $I ] [BOARD:BlackBox X32]
    [16:48:22] [ $I ] [AUX IO:1,0,0,0]
    [16:48:22] [ $I ] [WIFI MAC:C8:F0:9E:B3:50:A0]
    [16:48:22] [ $I ] [IP:192.168.7.129]
    [16:48:22] [ $I ] [PLUGIN:SDCARD v1.05]
    [16:48:22] [ $I ] [PLUGIN:ESP32 WebUI v0.03]
    [16:48:22] [ $I ] ok
    [16:48:22] [ $G ] [GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]
    [16:48:22] [ $G ] ok
    [16:48:22] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:22] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:22] [ ] [MSG:Caution: Unlocked]
    [16:48:22] [ ] ok
    [16:48:22] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:22] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:22] [ ] ALARM:1
    [16:48:22] [ ] [MSG:Reset to continue]
    [16:48:22] [ connect ] Firmware Detected: grbl version 1.1f on /dev/tty.usbserial-AQ02S2W0
    [16:48:23] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:23] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:24] [ ] [MSG:Caution: Unlocked]
    [16:48:24] [ ] ok
    [16:48:24] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:24] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:24] [ ] ALARM:1
    [16:48:24] [ ] [MSG:Reset to continue]
    [16:48:24] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:24] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:28] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:28] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:28] [ ] [MSG:Caution: Unlocked]
    [16:48:28] [ ] ok
    [16:48:28] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:28] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:28] [ ] ALARM:1
    [16:48:28] [ ] [MSG:Reset to continue]
    [16:48:30] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:30] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:30] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ $H ]
    [16:48:30] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ $H ]
    [16:48:30] [ $H ] ALARM:1
    [16:48:30] [ $H ] [MSG:Reset to continue]
    [16:48:30] [ $H ] ok
    [16:48:31] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:31] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:32] [ ] error: 2 - Numeric value format is not valid or missing an expected value. [ $H ]
    [16:48:32] [ ERROR ] error: 2 - Numeric value format is not valid or missing an expected value. [ $H ]
    [16:48:32] [ $H ] error:2
    [16:48:32] [ ] [MSG:Caution: Unlocked]
    [16:48:32] [ ] ok
    [16:48:32] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:32] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:32] [ ] ALARM:1
    [16:48:32] [ ] [MSG:Reset to continue]
    [16:48:32] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:32] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:33] [ ALARM ] ALARM: 6 - Homing fail. Reset during active homing cycle. [ $H ]
    [16:48:33] [ ] ALARM: 6 - Homing fail. Reset during active homing cycle. [ $H ]
    [16:48:33] [ $H ] ALARM:6
    [16:48:33] [ $H ] ok
    [16:48:33] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:33] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:33] [ ] error: 2 - Numeric value format is not valid or missing an expected value. [ $H ]
    [16:48:33] [ ERROR ] error: 2 - Numeric value format is not valid or missing an expected value. [ $H ]
    [16:48:33] [ $H ] error:2
    [16:48:36] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:36] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:37] [ ] [MSG:Caution: Unlocked]
    [16:48:37] [ ] ok
    [16:48:37] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:37] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:37] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:37] [ ] ALARM:1
    [16:48:37] [ ] [MSG:Reset to continue]
    [16:48:37] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:39] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:39] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:39] [ ] [MSG:Caution: Unlocked]
    [16:48:39] [ ] ok
    [16:48:39] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:39] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:39] [ ] ALARM:1
    [16:48:40] [ ] [MSG:Reset to continue]
    [16:48:40] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:40] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:41] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:41] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:41] [ ] [MSG:Caution: Unlocked]
    [16:48:41] [ ] ok
    [16:48:41] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:41] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:41] [ ] ALARM:1
    [16:48:41] [ ] [MSG:Reset to continue]
    [16:48:41] [ ] ok
    [16:48:42] [ ] [MSG:Caution: Unlocked]
    [16:48:42] [ ] ok
    [16:48:42] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:42] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:42] [ ] ALARM:1
    [16:48:42] [ ] [MSG:Reset to continue]
    [16:48:42] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:42] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:43] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:43] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:43] [ ] [MSG:Caution: Unlocked]
    [16:48:43] [ ] ok
    [16:48:43] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:43] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:43] [ ] ALARM:1
    [16:48:43] [ ] [MSG:Reset to continue]
    [16:48:44] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:44] [ ] [MSG:'$H'|'$X' to unlock]
    [16:48:45] [ ] [MSG:Caution: Unlocked]
    [16:48:45] [ ] ok
    [16:48:45] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:45] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:48:45] [ ] ALARM:1
    [16:48:45] [ ] [MSG:Reset to continue]
    [16:48:45] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:48:45] [ ] [MSG:'$H'|'$X' to unlock]
    [16:49:00] [ ] error: 9 - G-code locked out during alarm or jog state [ &HELP ]
    [16:49:00] [ ERROR ] error: 9 - G-code locked out during alarm or jog state [ &HELP ]
    [16:49:00] [ &HELP ] error:9
    [16:49:09] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:49:09] [ ] [MSG:'$H'|'$X' to unlock]
    [16:49:09] [ ] [MSG:Caution: Unlocked]
    [16:49:09] [ ] ok
    [16:49:09] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:49:09] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:49:09] [ ] ALARM:1
    [16:49:09] [ ] [MSG:Reset to continue]
    [16:49:53] [ $X ] [MSG:Caution: Unlocked]
    [16:49:53] [ $X ] ok
    [16:49:53] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:49:53] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:49:53] [ ] ALARM:1
    [16:49:53] [ ] [MSG:Reset to continue]
    [16:49:53] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:49:53] [ ] [MSG:'$H'|'$X' to unlock]
    [16:49:59] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:49:59] [ ] [MSG:'$H'|'$X' to unlock]
    [16:50:00] [ ] [MSG:Caution: Unlocked]
    [16:50:00] [ ] ok
    [16:50:00] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:50:00] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:50:00] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:50:00] [ ] ALARM:1
    [16:50:00] [ ] [MSG:Reset to continue]
    [16:50:00] [ ] [MSG:'$H'|'$X' to unlock]
    [16:50:01] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:50:01] [ ] [MSG:'$H'|'$X' to unlock]
    [16:50:01] [ ] [MSG:Caution: Unlocked]
    [16:50:01] [ ] ok
    [16:50:01] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:50:01] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:50:01] [ ] ALARM:1
    [16:50:01] [ ] [MSG:Reset to continue]
    [16:50:02] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:50:02] [ ] [MSG:'$H'|'$X' to unlock]
    [16:50:02] [ ] [MSG:Caution: Unlocked]
    [16:50:02] [ ] ok
    [16:50:02] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:50:02] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ undefined ]
    [16:50:02] [ ] ALARM:1
    [16:50:02] [ ] [MSG:Reset to continue]
    [16:50:06] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:50:06] [ ] [MSG:'$H'|'$X' to unlock]
    [16:50:09] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:50:09] [ ] [MSG:'$H'|'$X' to unlock]
    [16:50:12] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:50:12] [ ] [MSG:'$H'|'$X' to unlock]
    [16:50:13] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:50:13] [ ] [MSG:'$H'|'$X' to unlock]
    [16:50:14] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:50:14] [ ] [MSG:'$H'|'$X' to unlock]
    [16:50:26] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ ]
    [16:50:26] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ ]
    [16:50:26] [ ] ALARM:1
    [16:50:26] [ ] [MSG:Reset to continue]
    [16:50:26] [ ] ok
    [16:50:26] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [16:50:26] [ ] [MSG:'$H'|'$X' to unlock]
    [16:51:52] [ disconnect ] PORT INFO: Port closed
  2. John Tramell
    I've corrected the hard limit error and can now move the cutting head, but I still can not get the XYZ probe to work. It either does nothing but says its working or it moves to the center of the waste board and begins searching
  3. MIGUEL ANGEL PUMAREJO
    I installed everything correctly and it went great at the beginning and then -X went backward I fixed it and now the XYZ homing operation goes elsewhere, but not home. How can I fix this problem?
    #3 MIGUEL ANGEL PUMAREJO, Apr 12, 2023
  4. John Tramell
    Trying to update the firmware with the Flash tool, but it gives me this error as soon as it starts to write it. I feel like I'm missing a simple step but can't see it right now.
    [19:28:13] [ connect ] Firmware Detected: grbl version 1.1f on /dev/tty.usbserial-AQ02S2W0
    [19:28:26] [ Firmware Upgrade ] [Starting...]
    [19:28:26] [ disconnect ] PORT INFO: Port closed
    [19:28:26] [ Firmware Upgrade ] env: python: No such file or directory
    [19:28:26] [ Firmware Upgrade ] [exit:127]
    [19:28:26] [ Firmware Upgrade ] Firmware Update FAILED! Please review the logs above, or try again
  5. David the swarfer
    on a Mac? known python path problem
  6. David the swarfer
    turn homing off
    make sure jogging on each axis goes in the correct direction. +X is tool to the right, Y+ is tool away from you, +Z is tool up
    turn homing on
    adjust HOMING direction mask to make homing go in the correct directions to move toward your switches.
    dont forget to RESET the Blackbox after saving new settings
  7. John Tramell
    Yes, on a Mac, so what are my options?
    Fix/Install Python, or try a different computer
  9. David the swarfer
