Blackbox x32 - X-axis not working on first startup
Discussion in 'Controller Boards' started by Perry Hunter, Aug 2, 2023.
  1. Perry Hunter
    Hi there,
    I'm getting close to finishing my ratrig stronghold one with blackbox x32. I've got an annoying problem. When I startup the blackbox, the X-axis (or the axis I connect to the x-axis port) won't move. The control software does change the coordinates when I jog the axis, but there is no physical movement. When I go and turn the blackbox off and on again, the problem disappears, and I haven't had a problem after restarting it, until I power off and restart again. I first discovered this issue when test wiring the CNC, but thought it could be a bad connection thing. I have now rewired the whole machine, but the problem persists. Any idea on what might cause this
  3. Perry Hunter
    Thanks, I think that solved it.
    I had read about this elsewhere on the forum, but I stupidly thought the red exclamation mark that was mentioned, was the one in the control software, and I didn't have that on...
    Checkout out the Product Tour will help you to familiarise yourself with the hardware: docs:blackbox-x32:layout [OpenBuilds Documentation]
  5. Perry Hunter
    I know, RTFM... even after 55 years, it's still a struggle...;)
