hello im looking for some assistance iv just got my blackbox x32 calibrated and running . But my problem is im just using a z touch plate. I have wired it in and checked in the troubleshoot menu and it triggers green when you touch plate to the bit. I have put the measurements/ thickness in . Now when I run the probe function click the button nothing happens but if I just press the z down button just once it starts and go's down touches the plate and that's it not retracting and seems to be stuck in a alarm state because I have to press abort to get the controller to respond again . I have added some screenshots of what I'm getting back . I am pretty new to this and i have checked the wires and all seems ok like I said it dose trigger if you touch the clip to the plate the green light shows on the blackbox itself any help out there it would be much appreciated thank you
Did you follow all the setup steps in the BlackBox X32 documentation? Possibly skipped step 7.1? (Reading through Section 7.2 relates, so also worth a look): docs:blackbox-x32:firmware [OpenBuilds Documentation]
thank you very much peter yes your right. I must of missed that step seems to be working now thank you once again great product for people new to this cnc building lark
